Whipple stage 1 system for 496 mag! >
Old 01-21-2007 | 03:15 PM
Default Whipple stage 1 system for 496 mag!
Has anyone tried this for there 496 mag? If so what kind of gains did you see and how did the process work when buying.
pol98xc6 is offline
Old 01-22-2007 | 10:20 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Default Re: Whipple stage 1 system for 496 mag!
I have not heard anything bad. It will give you a noticable shot in the arm.. I would get a kit with the boost cranked down a bit though if you are planning on running it on a stock 496 setup.. The higher boost is not friendly on the stock internals. As far as an install, basically you remove the intake & install thhe whipple kit along with the fuel system & ecm.. If you want one feel free to give us a shout.. Jamie / lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 01-22-2007 | 10:29 AM
Jamie
I will be calling you tommorow to talk about that and the captains call!
Lucas
pol98xc6 is offline
Old 01-22-2007 | 12:04 PM
Jamie
Lucas
Lucas, Sounds good.. I will talk to you then..
Jamie / Lakeside Restorations 570-639-2628
Z06
6
01-23-2008 10:23 PM
mess
10
03-15-2006 12:49 AM
Blewbyyou
6
02-11-2004 03:46 PM
LIOPA
07-30-2002 11:26 AM
