Would you change anything in this combo? 509 SC Carb
Is there anything you would change right away in this combo to get it more reliable, more HP, better fuel efficiency etc?
The engine is as follows: Block: Merlin II 509ci Crank: Callies Rods: Manley H-Beam Pistons: JE blower pistons (757F) Comp: 8-8.5 according to engine builder Cam: UltraDyne mechanical flat tappet (J3854) 272º/282º Seat duration 238º/248º @ .050" 146º/155º @ .200" .550"/570" lift valve .3233"/.3353" lift lobe 114 LSA 15 16 (lobe master #) Heads: GM 188 Cast iron 118cc open chamber, 325cc intake volume Head gaskets: FelPro Wire-Loc Valves: 1.88/2.25 Rockers: Jesel Comp Series 1.7 Intake: Blower intake Blower: BDS 8-71 Boost: ~5psi Carbs: 2x Holley 9022 800cfm Ignition: Mercruiser Thunderbolt 4 Exhaust: Mercruiser/GIL Hi Performance According to engine builder (MDG Performance) it dynoed at 720-740HP@5600-5700rpm on 91 octane. Will be switching to and adding: Exhaust: Stainless Marine Gen III with 5" dry tails Intercooler: Superchiller Boost: 8psi Cam: Hyd roller by RMBuilder Bigger thermostatic oil cooler |
Re: Would you change anything in this combo? 509 SC Carb
Noone has any ideas?
Go with a slightly larger cam. I run a 598/610 crane 731 roller in my 509's and at 8 psi I am at 765 hp and over 825 torque
What color is it ? You may have the perfect motor! :rolleyes: :rolleyes:
Originally Posted by racinfever
(Post 2008265)
Originally Posted by Smitty
(Post 2008217)
Intercooler or not? At what rpm's? Thanks |
Get yourself an intercooler and a Crane marine ignition.When you say Mercruiser ignition,what do you mean?
Originally Posted by fastlane40
(Post 2008417)
I mean a Merc Thunderbolt 4. |
Of course an ignition will help.If you are using a Thunderbolt style your timing is set for a carbed engine.Can you imagine having a multiple spark ignition that you can set the same timing curve of the 600sc Merc, 800sc,525sc,900 sc and a heap of others with the turn of a switch.It also has a boost retard function and rev limiter built in.It comes in one box and is plug in to your existing harness.But best of all shipping doesn't cost you a fortune like it does me.Summit racing have them.They are about $291.Almost free.
Originally Posted by tomas_wallin
(Post 2007546)
Dave has been doing this for many years, I would not change anything, leave it set up as he gave it to you. He spent the time tuning it on a Dyno, so if you change it, you have lost that. I know he sets up his engines on the conservitive side but they live. |
| All times are GMT -5. The time now is 12:29 PM. |
