Best oil and sparkplugs? >
Old 01-26-2007, 04:44 PM
Default Best oil and sparkplugs?
I am about to give my new to me procharged 502 an oil and plug change. Just wondering what the best oil and plugs recommend in the powerboating scene is.
scarabsc is offline
Old 01-26-2007, 06:15 PM
Default Re: Best oil and sparkplugs?
A good synthic oil such as Mobile 1 10w30.I use that oil in my 502mpi Scarab scs and my high reving race car.
In regards to plugs not sure with a procharger.With my race car with nitrous I run a very cold plug.
Prostreeter is offline
Old 01-26-2007, 08:04 PM
Wooderson's Avatar
Do a search here on "Marine Lubrication" and you'll find the holy grail of all things oil related. Good luck!
Wooderson is offline
Old 01-26-2007, 09:25 PM
2112's Avatar
Having used almost all plugs, I have resigned myself to believing nothing holds a candle to NGK. They just do not have failures like many of the others
2112 is offline
Old 01-26-2007, 09:33 PM
Hydrocruiser's Avatar
Arrow Re: Best oil and sparkplugs?
10W-30 is too light for a 502.
NGK's give the smootest idle in a 502..
Hydrocruiser is offline
Old 01-26-2007, 11:09 PM
Really.Maybe I'm doing something wrong.For my altitude which is 6k feet 10w30 I thought was a good weight oil.Perhaps you can advise me as well whats a good weight oil.
Old 01-26-2007, 11:47 PM
cuda's Avatar
Any plug except Champions. I had one blow the electrode completely out. I thought I had puked an engine.
cuda is offline
Old 01-27-2007, 03:41 AM
Donzi502's Avatar
20-50 Pensoil or Kendells
Donzi502 is offline
Old 01-27-2007, 08:32 AM
Charter Member #927
Payton's Avatar
I would think that boating down south in warm water you would want to use a straight weight oil, if you run conventional oil. Not many syntetics are available in a straight weight so I would use a multi grade then. I use Amsoil Diesel and Marine.
I've been told NGK plugs are the best.
Payton is offline
Old 01-27-2007, 08:35 AM
monstaaa's Avatar
with out question, Mobil 1 15w 50 synthetic for all marine application engines. and NGK for the spark plugs, v-plus if you can for the cgarger app.
monstaaa is offline
Quick Reply: Best oil and sparkplugs?
