New exhaust question. >
Old 02-14-2007 | 07:29 PM
A 1-2mph gain.......maybe.
I agree. Alot of coin for that.
Ryan00TJ is offline
Old 02-14-2007 | 08:02 PM
Tinkerer's Avatar
If you plan on doing any other work to the engine I would seriously consider true header exhaust.
Be very carefull of aluminum exhaust.
If you overheat the engine due to lack of water flow the aluminum exhaust can melt down.
The headers ( steel ) will usually survive this.
Tinkerer is offline
Old 02-14-2007 | 08:59 PM
JasonSmith's Avatar
Dana marine manifolds!
JasonSmith is offline
Old 02-15-2007 | 04:58 PM
I have EMI exhaust and I am very satisfied. Expect 1 or 2 MPH gain. This is the best place to start with the upgrades. You get rid of the wet riser joint and improve reliability. Any engine mods you do, especially the Cam would need them anyway. It is better if you ditch the silent choice, if you want to reduce the noise use mufflers to compensate.
Good luck!
jeffswav is offline
Old 02-15-2007 | 05:08 PM
I agree with Griff. 1-2 MPH gain at the most.
David Stotz is offline
Old 02-15-2007 | 07:22 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I replaced my heavy azz stock exhaust last yr with SM. Lost a good 80# between both motor change overs, but seen zero speed gains. Motors have a different sound now. More of a tingy sound now than the deep tone the cast steel gave it.
My previous boat had a blower motor with straight thur hull Merc/Gill exhaust. I got tired of the fulltime loudness real quick. Installed silent choice, had no speed loss.
US1 Fountain is offline
hpy540
8
11-22-2005 07:14 PM
THE GOOD STUFF
03-03-2004 09:17 PM
formula1
05-25-2002 07:59 PM
thisistank
Baja
17
03-24-2002 10:50 AM
