KPM Pump Impellers >
KPM Pump Impellers
KPM Pump Impellers
Old 02-20-2007 | 05:07 PM
blue thunder's Avatar
Default KPM Pump Impellers
Will a stock bravo sea pump impeller work in a KPM pump? How about one of those globe blue impellers? I need to replace one that flew apart and have had no luck getting a replacement.
BT
blue thunder is offline
Old 02-21-2007 | 09:16 AM
Mr Gadgets's Avatar
Charter Member #601
If you are using the sea water replacement pump from KPM, I was told the stock impeller would fit. That is the one that you bolt the front pulley housing on to..
Hope this helps.
D*ck
Mr Gadgets is offline
Old 02-21-2007 | 04:46 PM
Yeah thats the one Mr G. I thought they looked like the bravo impeller but don't remember for sure. The one in this engine disinegrated so I can't compare it to a bravo piece, and the one in the other engine is still mounted and working fine and I'm too lazy to tear it out just for that. Thanks for the feedback.
BT
Old 02-21-2007 | 08:36 PM
KPM claims that they are different but they don't look different to me. Call Fred at Trick Marine and he will give you an honest answer.
SkiDoc is offline
Old 02-21-2007 | 10:38 PM
offthefront's Avatar
BT
better find those pieces .....at least back flush ....m
offthefront is offline
Old 02-22-2007 | 04:03 PM
Yeah I backflushed them alright offthefornt, right back into the drive .... doh. Oh well, that was an easy fix although rather annoying.
How about the globe blue impellers? I image they would work with the kpm too then? Seems like that would add some additional insurance.
I sent an email Sunday Too Old with my address. You may need to scroll down the email a bit because it was a resend of an earlier email. Let me know if you didn't get that email.
BT
Old 02-22-2007 | 04:07 PM
Ironic, I just finished this post an looked up an there was the answer on the blue impellers.....
Resilient Blue Impellers, THE ONLY IMPELLER IN THE WORLD THAT'S GUARANTEED TO RUN DRY FOR 15 MINUTES! Non swelling, shrinking, oil & solvent resistant, self lubricating, anti brittling, abrasion resistent, won't stick to pump housing, that performs in all enviornments, extending service life. OEM REPLACEMENTS FOR MERCURY, ILMOR, STERLING, KE-HARDIN, KPM. E-mail to check on your application.
StrikinLightnin
09-09-2008 07:08 AM
duksrule
03-05-2007 06:54 PM
Mr Gadgets
4
06-07-2006 07:56 AM
SkiDoc
17
05-09-2006 08:38 AM
DanL
1
05-22-2002 10:58 PM
