older Merc trim / tab pumps - fluid checking ? >
Old 02-22-2007 | 03:43 PM
jaybird's Avatar
Default older Merc trim / tab pumps - fluid checking ?
I have older trim pumps (late 80's) TRS setup w/ trim and tab pumps that do not have the separate reservoir. Do the drives / tabs need to be in a particular position (all the way up / down ) to correctly check the levels? Also what type of fluid should be used - brake / hydraulic fluid ?
Thanks!
jaybird is offline
Old 02-22-2007 | 04:19 PM
stageharbor's Avatar
Go Big or Go Home
Drive should be all the way down, tabs should be all the way up. You can use hydraulic fluid or motor oil. Never brake fluid.
stageharbor is offline
Old 02-22-2007 | 04:54 PM
jaybird's Avatar
ok thanks.
What if I don't know what's in there, is it ok to mix hydraulic fluid and motor oil, or do you need to drain / bleed the system? If so that will be my next question - how to bleed?
Thanks.
jaybird is offline
Old 02-22-2007 | 07:00 PM
H2Xmark's Avatar
I would not mix them, a friend of mine had mixed and his fluid started to gel and get thick, bleed by operating unit up and down a few times and keep fluid level to the full mark
H2Xmark is offline
Old 02-23-2007 | 09:15 AM
jaybird's Avatar
Ok - I guess I should of asked how to drain these pumps 1st!
jaybird is offline
502ss
10
09-11-2008 07:09 AM
Stormrider
2
07-06-2005 09:20 AM
Sydwayz
4
10-06-2004 11:50 PM
matrin
Powerquest
13
09-19-2002 07:03 PM
