Fresh Long Block - Which Cam >
Old 02-25-2007 | 03:50 PM
Elite Marine's Avatar
Default Fresh Long Block - Which Cam
I had my 454 (bored .030) freshened. It has Dart Iron Eagle Heads, Rev Valves, Crane Gold Rockers, Isky Springs, Forged Crank, Eagle Rods, new Melling Oil Pump, JE Pistons and new rings.
Looking for a cam to install and sell the completed long block.
Was hoping to get a buyer and let them choose the cam.
What cam would you recommend??
Elite Marine is offline
Old 02-25-2007 | 07:15 PM
Crane 168731
http://store.summitracing.com/partde...1&autoview=sku
Griff is offline
Old 02-26-2007 | 01:19 PM
Jmemoli's Avatar
Goumada P5-38
Comp G6 XR271HR -12 hydraulic roller -
This is a bit more mellow than the crane 168731 but will make more torque -
Call CP performance - they have it in stock
Jmemoli is offline
Old 02-26-2007 | 03:06 PM
If you were purchasing the engine which would be prefered???
Old 02-26-2007 | 03:13 PM
Or if you know of anyone interested ina very well built strong 460, let me know!!
Old 02-27-2007 | 05:45 AM
Jmemoli's Avatar
Goumada P5-38
The crane series mentioned has very slow opening and closing ramps and will bleed off cylinder pressure . The comp extreme lobes are new designs . Plus , they are much less $$ than what the summit catalog charges from CP .
I would prefer a comp cam over a crane .
Also , this mellow profile will work with well with about any exhaust used on the engine , and will not have reversion problems .
Jmemoli is offline
Old 02-27-2007 | 04:58 PM
kewler's Avatar
how much do you want and what comes with it
kewler is offline
Old 02-27-2007 | 05:49 PM
nordic95's Avatar
I have two matching roller cams listed in the swap shop.If interested I could give details.I am cleaning out my garage,so make me an offer.
Thanks Nordic95
nordic95 is offline
Old 02-27-2007 | 08:39 PM
Default Here's what I have
4 Bolt Gen VI 454 (bored .030) freshened, Dart Iron Eagle Heads, Rev Valves, Crane Gold Rockers, Isky Springs, Forged Crank, Eagle Rods, new Melling Oil Pump, JE Pistons, new rings, new bearings. As far as tin - Timing chain cover (aluminum) and oil pan. I do have accessories, but wasn't installing them.
This engine is fresh with "0" time on it from Ateco Engine and Dyno Shop.
Old 02-27-2007 | 09:22 PM
Outdrive1's Avatar
Masher touches my
What's a comp cam that would compare to a crane 168741?
Outdrive1 is offline
Rockfish71
4
05-29-2008 01:39 PM
smokin' gun
Wanted
1
04-15-2008 11:27 PM
chrisf
01-13-2006 04:44 PM
Dregsz
0
06-25-2005 12:26 AM
suncoastdave
0
09-08-2004 04:14 PM
