Looking for bravo lower gears >
Old 02-27-2007 | 04:28 PM
Default Looking for bravo lower gears
I dont know where to post this. My lower is apart and the gears are shot. The nut came loose but didnt grenade. So I need basically all of the guts... shafts included. Or a lower complete ready to bolt on. I am in Northern Illinois.
HPJunkie is offline
Old 02-27-2007 | 09:33 PM
t500hps's Avatar
21 and 42 footers
I've seen several sets on ebay recently
t500hps is offline
Old 02-27-2007 | 09:58 PM
Is your lower a xr style or std.What gear ratio? I have a lot of bravo parts and can probably help you out .Give me a call at shop 410-956-5381 Dave
MDGperformance is offline
Old 02-28-2007 | 12:47 PM
Mr Gadgets's Avatar
Charter Member #601
What kind of power are you running? What are you looking for? Standard, XR, Imco??
Lots of possibilities.
D*ck
Mr Gadgets is offline
Old 02-28-2007 | 12:57 PM
Thought about a shorty?
Stingray69 is offline
Old 02-28-2007 | 06:24 PM
Smitty's Avatar
I've got a lower with around 90 hrs on it. It has low water pickups on it. Give me a P.M. if you're interested.
Smitty is offline
Old 02-28-2007 | 06:58 PM
Mr Gadgets's Avatar
Charter Member #601
HP,
I have a case coming back from the body shop next week. Had a Hydromotive nose cone put on it and new paint.. I took a look in the shop and I have enough to fill it with either Standard Bravo or XR shafts, new or used gears, but all the gears are going out for processing this week. This lower is side water pickup, lower gears I have available are 1.5:1.. So between all the responders, you have quite a selection to choose from. Let me know if I can be of help.. Feel free to give me a call if you want. If not, I know Smitty takes real good care of his equipment!!
By the way Smitty, I tore down your lowers tonite.. they look real good inside!! The gears will be headed to processing this next week..
D*ck
616-335-8446 home before 8:30pm EST
616-403-1006 cell day light hours
I almost forgot.. I have a couple of extra cases, lwp, dwp, and the one with the nose cone. Selection, selction, selection....
Old 02-28-2007 | 07:41 PM
Default gears
What Are You Doing To The Gears To Treat Them Have You Ever Tryed The Mikronite Process On Them
dennis r is offline
Old 02-28-2007 | 08:42 PM
Mr Gadgets's Avatar
Charter Member #601
Dennis,
I am not sure what that process is. These are cryoed and then a polishing process is done to them. Articfriends did a test using this process on lower gears last summer and had good results with it. I am doing XR uppers and the lowers.
Weren't you going to bring me your drive.. been so busy I cant remember, but we should get that scheduled.. Give me a call tomorrow..
D*ck
Old 02-28-2007 | 10:13 PM
My lower is a std unit. The upper is 1.5 ratio. The new parts are outa site in price. I didnt expect this problem, I was just switching cases to a nosecone unit for an increase in speed. Its killing me as I am just getting the motor fixed now from the last june's friday night all you can eat piston fry. So I really appreciate you guys helping me on this. Dave and D*ck...Ill call you guys tomorrow. Smitty I cannot PM.... could you call me at 815-509-0856? Thanks Greg
HPJunkie is offline
