-   -   454 ignition module (https://www.offshoreonly.com/forums/general-q/152503-454-ignition-module.html)
kennyo 02-28-2007 03:33 PM
454 ignition module
will the ign module from an ' 89 model 330 hp interchange with a '96 model 330 hp motor. Both were carb engines
Griff 02-28-2007 04:26 PM
It should, as long as both are TB IV modules.
offthefront 03-01-2007 06:46 AM
should work cept the 89 wont have Rev limiter ....
Dave_N 03-01-2007 10:01 AM
Assuming you use a module with an appropriate advance curve for your engine, a Thunderbolt IV ignition module will work with the Thunderbolt V dist.
You will need the correct wire harness (not the main harness just the small dist to coil sub-harness). In addition to the loss of the rev limiter, you will also lose the knock monitoring, Mean Best Timing, and idle speed control of the T-bolt V.
Dave
Griff 03-01-2007 06:40 PM
No Thunderbolt IV modules have a rev limiter. Rev limiters with TB IV's were on Merc Racing/Blue engines only and are a separate component and can be added or removed.
