-   -   Bravo 1 to X or XR (https://www.offshoreonly.com/forums/general-q/152582-bravo-1-x-xr.html)
Michael1 03-01-2007 03:01 PM
Bravo 1 to X or XR
Can a Bravo 1 be swapped out for a Bravo X or Bravo XR without changing the transom mounting?
Do all three have the same X-dimensions?
Michael
HighPriority 03-01-2007 03:43 PM
Yes
offthefront 03-01-2007 04:36 PM
1 Attachment(s)
Michael
The X-dimentions might be the same but the assemblies are different .. a Bravo I will work on a HP but the XR drive will not work on a Standard BI assembly .. I think ...:)
I know that the HP's dont have the provisons for Senders (who cares) ....
http://biggunsmarine.com/product_inf...3032479fc83091
t500hps 03-01-2007 05:38 PM
As I understand it.......An XR will go into a regular Bravo transom, the XR will not but only because the bearing needs to be changed to the XR version.
Griff 03-01-2007 06:34 PM
The transom assembly will work. You have to change a couple things. I think merc makes a kit for it.
The drives when installed will give the same propshaft depth.
Hydrolift 03-01-2007 06:45 PM
You will need to change the gimbal bearing and the aliminium sleeve. Did it last winter changed from Bravo 1 ('87) to a Bravo X ('01)
Pat McPherson 03-01-2007 07:12 PM
Yes, you can bolt a HP drive to a standard transom assembly as stated above. There is a kit from Merc to do just that. New bearing, sleeve, and spacers for the pistons as to not over trim the bigger U-joints.
