Number 6 rooster tails? >
Old 03-05-2007 | 05:49 PM
PIGPEN160's Avatar
Default Number 6 rooster tails?
Not having number 6 drives, someone enlighten me as to what causes the big rooster tail. Also, has anyone played around with TRS drives or tried to attach something to get such a rooster tail?
PIGPEN160 is offline
Old 03-05-2007 | 06:36 PM
Payton's Avatar
Charter Member #927
A portion of the prop runs out of the water. That's the reason for the rooster tail.
Payton is offline
Old 03-05-2007 | 08:31 PM
SSM 6's are surface piercing drives. When running and trimmed up, a portion of the prop is breaking the surface of the water. They also run props designed to pierce the surface of the water. TRS's are not made for that and "adding" something to get a rooster will increase prop slip and reduce top speed.
Griff is offline
Old 03-05-2007 | 08:34 PM
Fenderjack's Avatar
Pirate of the Chesapeake
Just keep hitting the trailer button, that will give ya one... Syke don't do that----booom---
Fenderjack is offline
Old 03-06-2007 | 08:25 AM
IRONMAN's Avatar
About the only thing that you can add to get more tail is hydromotive props and Konrad drives, the Konrad is about 1.6" shorter than the TRS and the pointed blades on the true 15.5 diameter hydromotive prop will pierce the surface more. A rather expensive method and you still will not have a tail like a 6
IRONMAN is offline
Old 03-06-2007 | 08:28 AM
t500hps's Avatar
21 and 42 footers
Buy Cuda's KAAMA 302 Formula....(surface drives)
t500hps is offline
Old 03-06-2007 | 11:01 AM
When we were kids we used to trailer the drive up past the trim limit and make tails. Lots of slip, speed loss, revs would go up but it would stay on plane and make a huge tail. Tough on the gimbal and ujoints but we didnt even know what ujoints were at that point. Nothing ever failed but I wouldnt do it now.
Pismo10 is offline
Old 03-06-2007 | 11:11 AM
tblrklakemo's Avatar
SeaRay Sundancer
You can attach an arneson and spray tail all day long.
tblrklakemo is offline
Old 03-06-2007 | 12:16 PM
carrboy's Avatar
They have the bravo/arneson conversions now that will do the same thing(2 blades in the water and 2 blades out).Nothing as strong as the arneson though.
carrboy is offline
Old 03-06-2007 | 12:49 PM
racer-x6's Avatar
What would happen if I run a Bravo sport master stand. length without the cavitation plate?
racer-x6 is offline
