Air Conditioning, is it difficult to rig on a boat? >
Old 03-06-2007 | 08:04 PM
Elite Marine's Avatar
There is a Nauticool for sale in the classifieds for a great price!!
I saw it the other day.
Elite Marine is offline
Old 03-06-2007 | 10:06 PM
The Eliminator 36 Daytona Coupe has A/C. You might see what they used.
Michael
Michael1 is offline
Old 03-06-2007 | 10:50 PM
SeaRay Jim's Avatar
I believe it's Nauticool....
SeaRay Jim is offline
Old 03-07-2007 | 08:25 AM
Liquid Fix's Avatar
Nauticool, talk to John B. I was told about $$3600 for the system and around $2000 for install.
From Johns E-mail
"The standard system is $3595.00 and installation ranges from $1000.00 to $2000.00 here at our location, depending on the difficulty level of the install."
LF
Liquid Fix is offline
Old 03-07-2007 | 08:46 AM
Panther's Avatar
Frank's Marine Service
Originally Posted by Brad Zastrow
Yeah, I need the system that runs off the engine much like a car. Weight is slight factor as well. It is going in a race canopy boat. Need to keep the cockpit cool at 100 mph.
How about a car junkyard??? Conversion should be pretty easy, no?
Panther is offline
Old 03-07-2007 | 09:02 AM
Brad Zastrow's Avatar
Wow that is pricey. There are complete auto kits for under $1000 for hot rods. I may look into that.
Brad Zastrow is offline
Old 03-07-2007 | 09:18 AM
Yeah, just mount the condenser in the tunnel!
As with the marine 110V air conditioners, my bet is you're paying for the heat exchanger. 5000 BTU Walmart window unit $100, 5000 BTU Cruisar $1000.
Gary
rdoactive is offline
Old 03-07-2007 | 11:45 AM
Mike Paula's Avatar
This woukd not be had to do. I have never looked into aftermarket systems but if it was me I would look for one you can buld custom hoses so you can custom fit it to your system I know there are companys that make one for school busses. The hard part will be to get the condenser in a location that will alow air flow to it to do its job
Mike Paula is offline
Old 03-07-2007 | 01:02 PM
Realistically, I dont see why you couldn't use an auto compresor (pulley changed for corect rpm), an auto dryer and evaporator. And the marine freon to water heat exchangers are simply a copper tube within a tube. If you couldn't salvage an old marine one, I would think you could make one.
Anyone want to try?
Gary
Old 03-07-2007 | 01:42 PM
44MTI's Avatar
I have looked into this as well. MTI has had some problems with the nauticool systems and no longer offers it as an option. Gary did convert an automotive system for GC Motorsports that works well.
I think the best option is a 110V system with an inverter mounted in the storage space infront of the cockpit. Outerlimits uses this system in their GTX's, only they use 2 A/C units and one small generator. This is also what will go into Gold Digger as I understand it.
44MTI is offline
