oil pump pickup 525sc
Im starting to put my gen VI 25sc back together and I cant find a new oil pump pickup. Anyone know what pickup works with the stock pan that comes on the 525sc? I couldnt find a pickup through mercruiser, is it even available?
thanks |
Try Melling. Big name in oil pumps.
melling.com |
I guess I should say i dont know which type of pickup to get. Is it just a stock style gm oil pump pickup? or is it a different length because of the pan?
ss,
I think the only way you can get the pickup from Mercruiser is to buy the pump assembly which comes with the screen tig welded to it. There is a Melling part number that will work although it does not look identical to the MC one. It also puts the pickup a bit further to the back of the pan but does not seem to cause a problem. I have the part number at the shop but will not be there till Monday. Bill Koustenis Advanced Automotive Machine Waldorf Md |
bill if you can would you mind finding out that part number for me if you still can?
thanks
Originally Posted by BillK
(Post 2052686)
ss,
Originally Posted by ssilverado60
(Post 2061906)
thanks |
| All times are GMT -5. The time now is 11:08 AM. |
