cam choices
Old 03-13-2007 | 10:08 AM
Default cam choices
have a Genv 502 that wiped out a cam lobe. I am in the process of putting it back together after boil-out and machining. would like to switch to a roller cam.which one would be a good choice? The motor still has the stock pistons, which were okay. Heads have been milled .040, stainless valves, roller rockers,EMI Thunder exhaust with short stainless risers, silent choice,800dbl pumper,stock dual plane intake.Will a Gen6 timing set with the thrust plate work with this set-up?
slo poke is offline
Old 03-13-2007 | 11:29 AM
Gen 6 will work you will work but in the long run maybe more expensive then using the Gen 5 steel cover with a "flat face" hyd roller core.
cstraub is offline
Old 03-13-2007 | 07:56 PM
You better check those pistons real good.
If you wiped out a cam lobe I bet you have metal on the sides of the pistons.
1BIGJIM is offline
Old 03-13-2007 | 09:01 PM
KAAMA's Avatar
Welcome to the OSO forum. If you're in the market for a cam then call RMbuilder/Bob Madara of Marine Kinetics 585-654-8583 EST. For about $60 or so more Bob will custom engineer a cam for your specific application. He has helped many guys in the past few years here on OSO with cam apps.
KAAMA is offline
Old 03-14-2007 | 09:39 PM
Will the Gen VI setup (stepped nose cam and single row chain) fit under the Gen V timing cover?
badluck is offline
Old 03-15-2007 | 06:51 AM
Default cam choices
That is what I would like to find out. I am a little leery about cam buttons with a stamped steel front cover.
slo poke is offline
Old 03-15-2007 | 09:09 AM
TC's Avatar
TC
badluck & slo poke, I used that set up on my 496 build. Works fine.
TC is offline
Old 03-15-2007 | 09:16 AM
The stepped nose will fit fine. Just buy the gen 6 retaining plate and timing set. Like was mentioned above you most likely have metal throughout the engine so it needs to be cleaned thoroughly.
bobl is offline
Pat Haener
4
10-18-2006 07:05 AM
Scott
7
02-25-2003 08:59 PM
CONVINCOR 251
9
09-29-2002 04:38 PM
hattman
06-15-2002 10:21 PM
Scott
2
03-08-2002 08:10 PM
