-   -   Shift cutout switch...Bravo? (https://www.offshoreonly.com/forums/general-q/153915-shift-cutout-switch-bravo.html)
jdub 03-18-2007 04:55 PM
Do Bravo drives need or use shift cutout switches?
Biggus 03-18-2007 06:26 PM
no
klaw 03-18-2007 07:10 PM
the drive has no need for a switch but in the mercury engine circuit there is a neutral safty switch . the drve must be in neutral for engine to start
jdub 03-19-2007 05:38 AM
thanks
242LS 04-09-2011 07:12 PM
I just cracked one of my Shift Cutout Switches (Alphas). 3 questions:
1) Is the purpose of this switch so you don't start the engine in gear?
2) What is the logic? Closed circuit disables ignition? ...or open circuit disable ignition?
3) If open disables, hardwiring will defeat that check? (Not that I want to, but I want to be able to run while waiting for the part).
Thanks.
FIXX 04-09-2011 07:47 PM
Fixx
Thanks.
the purpose of the cutout switch is so you can pull the drive out of gear, it kills the engine for a split second..if their not hooked up the drive will stay in gear even tho the control is in neutral.
thats if this is the switch on the shift cable assenbly...all you have to do is shut the engine off before you try to take it out of gear,once out you will have to restart and select your other gear...it will be a pain to dock with out this switch..
242LS 04-09-2011 11:28 PM
Got it - thanks. That helps.
ROTAX454 04-10-2011 08:41 AM
Reading this thread, do I sense a difference of opinion.
1) Switch that is connected to the starter circuit.
2) Switch that is connected to the ignition circuit.
Which is the correct? Or both? Wiring is right up my alley and designing/building a wire harness to perform would be easy.
bigblue 04-10-2011 04:54 PM
My buddy needed it on his alpha 454 combo. My bravo 454 didnt need it. Must be how the gears are cut????
Too Stroked 04-10-2011 05:38 PM
The Bravo drive uses Cone Clutches to shift. The Alpha is pretty much like an outboard - just jamming the gears together. That's why you need a shift / ignition interrupter when you shift. It allows the gears to mesh safely.
