Anti-seize and Spark plugs >
Old 03-23-2007 | 10:02 PM
gripit's Avatar
Default Anti-seize and Spark plugs
This may be a dumb question but, does anybody put anti-seize or anything on spark plugs?
gripit is offline
Old 03-24-2007 | 12:06 AM
I always do on aluminum heads.
phebus is offline
Old 03-24-2007 | 12:20 AM
articfriends's Avatar
I always use a tiny bit too to keep lugs from galling the threads,its just good practice,Smitty
articfriends is offline
Old 03-24-2007 | 12:28 AM
J-Bonz's Avatar
Through other work experiences I found it very benificial to apply a little also, like preveously stated, especially in an aluminum head application
Jr.
J-Bonz is offline
Old 03-24-2007 | 08:21 AM
Yep, even my lawn mower, pressure washer, weed whiper, and chain saw.
johnny b good is offline
Old 03-24-2007 | 09:31 AM
BY U BOY's Avatar
YES on aluminum heads.
BY U BOY is offline
Old 03-24-2007 | 10:46 PM
Reed Jensen's Avatar
I've had better luck with a little engine assembly lube with moly. But yes, if you have aluminum heads you need something to keep them from seizing.
Reed Jensen is offline
Old 03-24-2007 | 11:29 PM
J-Bonz's Avatar
.............................................AGREE !!!!!!!!!!!!!
J-Bonz is offline
Old 03-24-2007 | 11:35 PM
10x's Avatar
10x
10x
Yup, all the above, PLUS...... on every stainless nut and bolt to keep them from seizing up when loosening them.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 03-25-2007 | 07:42 AM
CMG's Avatar
CMG
would anti-seeze make a difference on older Fords that rust the plugs in place?
Chris G.
CMG is offline
