Spark plug gap >
Spark plug gap
Spark plug gap
Old 03-24-2007 | 10:02 AM
gripit's Avatar
Default Spark plug gap
What would be the correct gap on a 454 with dart iron eagle heads and holley 750? I'm using AC delco plugs. Thanks
gripit is offline
Old 03-24-2007 | 11:09 AM
Hydrocruiser's Avatar
Arrow
My best guess is .035
Hydrocruiser is offline
Old 03-24-2007 | 12:23 PM
Pwrbt33's Avatar
If you dont have MSD or like ignition leave it at .035.
Set your timing around 30 to 32 degree's.
John S.
As far as anti-sieze, just a touch of it on the threads will do. What ever you do, do not use grease.
Pwrbt33 is offline
Old 03-25-2007 | 05:24 AM
cig1988's Avatar
What plug # are you using ?
cig1988 is offline
Old 03-25-2007 | 05:50 AM
Craney's Avatar
John S.
What should your gap be when using MSD?
Craney is offline
Old 03-25-2007 | 08:40 AM
Pwrbt33's Avatar
With an MSD or Crane box you can get away with .038 to .040 on the gap. The plugs seem to last a little bit longer with the larger gap. At .035 they seem to burn up faster.
John S.
Pwrbt33 is offline
Old 03-25-2007 | 09:52 AM
KAAMA's Avatar
In reference to a Crane ignition box---don't quote me, but I think it says in their manual they recommend a .045" gap on a spark plug using their Hi-6M ignition box with their PS-92 coil. Whether a .045" gap is truly a good place to gap it at I really don't know.
KAAMA is offline
Old 03-25-2007 | 09:58 AM
cuda's Avatar
With a high output coil, you should be able to run a .45 gap.
cuda is offline
Old 03-25-2007 | 10:35 AM
Pwrbt33's Avatar
I've run our 1200 Cobras at .045 when we got them back from Randy and the plugs would foul and wear out quick. I tightened the gap up to .040 and got double the amount of hours out of them. Just my personal experience. A lot of other people will tell you the same as you also.
John S.
Pwrbt33 is offline
fund razor
3
05-16-2005 09:07 AM
THRILLSEEKER
2
05-11-2003 04:55 PM
Chart
10
05-02-2003 06:07 PM
99Hammer
6
06-21-2002 03:17 PM
