-   -   Best Way To Clean Vinyl (https://www.offshoreonly.com/forums/general-q/154492-best-way-clean-vinyl.html)
satisfactionII 03-26-2007 05:53 PM
Originally Posted by outlawinil (Post 2071491)
what the heck is magic erasers?
Mr. Clean Magic Erasers. I use them all the time. The work great.
t500hps 03-26-2007 06:07 PM
2 years ago I cleaned some seats with bleach white (cut 50%with water) and a medium brush. Worked my AZZ off scrubbing everything. A couple days later I was told to try the Magic Erasers......you could see where I left off when I stopped 1/2 way through. Use small amounts of cleaner along with the Erasers, Spray 9 cut significantly or even Windex cleaners will help the Erasers clean even more quickly. I will use nothing else on my vinyl from now on!!!!!
East Coast B 03-26-2007 06:17 PM
I've had good luck with "Vinyl Shampoo". That's the name! Think I got it through boaters world! Then I top it off with mcguires vinyl conditioner in the blue spray bottle....
klaw 03-26-2007 06:19 PM
lava soap works great
US1 Fountain 03-26-2007 07:17 PM
The bad thing about the Magic Eraser is that you can't just try it. Once you try it in a spot, you have to do the rest of the interior. :)
I always follow up with 303.
ghittner 03-27-2007 12:52 AM
SOAK it with Simple green for 15-20 min or so. Then scrub with a soft bristle brush thoroughly and wipe off. Spray again, wipe again, it will look showroom and you won't have to worry about a caustic cleaner to boot! It works!
kennyo 03-27-2007 07:45 AM
ditto!
jeff1000man 03-27-2007 11:03 AM
What is the 303? I have seen it mentioned a couple of times around here.
320es 03-27-2007 12:17 PM
vinyl protectant
JCat 38 03-27-2007 12:36 PM
I swear by Magic Erasers dipped in Quick n Brite, it does the best job. Stay away from anything that has bleach, it will crack your vinyl and so will amorall. We have switched over to 303, it may be more $$$, but it sure beats replacing all your vinyl.
