Engine wiring harness >
Old 03-27-2007 | 06:00 AM
Default Engine wiring harness
Anybody use the aftermarket engine harness that Trick or CP performance sells. Are all the wires you need in the harness or did you find that you had to run seperate ones?
jdub is offline
Old 03-27-2007 | 06:04 AM
Michigan Mad Man
We make our own wiring harnesses that are a Merc replacement. We have engine only, Efi harness and a harness that runs up to the dash. Tyler 8103242720.
TylerCrockett is offline
Old 03-27-2007 | 09:51 AM
offthefront's Avatar
hmmmmm good to know .....m
offthefront is offline
Old 03-27-2007 | 07:47 PM
Elite Marine's Avatar
Ateco also supplies harnesses. Stock and custom.
Call Bill at (847)623-2737
Elite Marine is offline
Old 03-28-2007 | 06:09 PM
I would like to check out your harnesses as Ill be at that stage of a rerig soon!any thing to see online?
sschafee01@snet.net is offline
Old 03-31-2007 | 08:27 PM
monstaaa's Avatar
with all due respect to all the other pro's, i ve yet to see anything beat a merc harness. which is why you have this thread to begin with.
if there is one out ther i would like to know of it and maybe you guys can shoot me an e-mail or p,m about it.
good luck to all
monstaaa is offline
Old 03-31-2007 | 08:31 PM
My problem is I got rid of my EFI and the harness went with it. I now need a new harness but not sure which to use. New motor is a carbed 509.
jdub is offline
Old 03-31-2007 | 10:37 PM
monstaaa's Avatar
merc harness for a gen IV b.b
monstaaa is offline
Old 04-01-2007 | 06:56 AM
Only problem with that is the GEN IV harness plugs in at the exhaust elbow on the shift bracket. My harness from gauges to motor is at the center of the transom with about 1 foot of tail (won't reach). It was previously set up for a GEN V EFI that plugs in at the rear of the motor.
jdub is offline
Old 04-01-2007 | 07:40 AM
rws's Avatar
rws
I used a $69 harness from Fred on my carbed big block,did not have to run any additional wires.Plug fit was good,no problems.
Rob
rws is offline
Maritime_Eng
0
08-15-2008 08:33 AM
ciaoderhead
05-13-2008 01:30 PM
Shah Mat
05-30-2006 01:18 PM
jryan26
Fountain
3
05-11-2006 12:55 AM
Leathl_WS6
12
12-21-2004 04:54 PM
