atlernator wiring?? >
atlernator wiring??
atlernator wiring??
Old 03-31-2007 | 10:49 AM
ITLLFLI's Avatar
Default atlernator wiring??
I am trying to update and old 87 supra skiboat. It had a 351 PCM but we replaced with a custom 351. The parts place shipped me the wrong alternator.
The original one had 3 wires.
-orange..positive
-black..ground
-green wire..
The new alternator is like our mercruiser ones with the 2 small gauge wires(pink and purple).
How can I wire the new alternator in? Here is a pic of the wire harness and apic of the new alternator.
Attached Thumbnails atlernator wiring??-pict6614.jpg   atlernator wiring??-pict6613.jpg
ITLLFLI is offline
Old 03-31-2007 | 08:15 PM
monstaaa's Avatar
black= ground
large red= pos.
purple= excite
pink= ign.
monstaaa is offline
Old 04-01-2007 | 09:37 AM
ITLLFLI's Avatar
Originally Posted by monstaaa
black= ground
large red= pos.
purple= excite
pink= ign.
Just to be clear.....
What is the function or where does the "excite" wire go?
What is the function or where does the "ign" wire go?
ITLLFLI is offline
Old 04-01-2007 | 01:03 PM
monstaaa's Avatar
merc alternarors should be marked.
monstaaa is offline
Old 04-01-2007 | 01:54 PM
Merc/mando 4 wire alternators are wired as follows:
Large red, post on alt to starter, supplies the output.
Black, ground, self explanatory.
Purple is the excitation wire. It's on when the key is in run. It tells the alternator to charge.
smal red, or red stripe, is sensor. This meters voltage in the circuit and compensated for loss up to the dash.
You'll need to determine if your pink wire is hot all the time (sensor), or switched (excitation). Then add the needed wire.
What type of connector do you have for the 2 small wires?
Gary
rdoactive is offline
Old 04-02-2007 | 09:01 AM
This might help:
http://www.marinemechanic.com/site/page250.html
Old 04-03-2007 | 08:47 AM
Wally's Avatar
Were doomed!
this may help you too...
http://www.arcomarine.com/xhtml/Tech...tor%20tips.pdf
-Wally
Wally is offline
Old 04-03-2007 | 02:15 PM
ITLLFLI's Avatar
I think I am pointed in the right direction!
Thanks!
ITLLFLI is offline
johnlomant
Nordic
2
02-22-2010 11:36 PM
06zx10r
05-30-2007 01:33 PM
hp500efi
6
04-30-2007 10:47 PM
JJONES
0
06-07-2004 12:44 PM
klmken
4
04-17-2002 09:50 PM
