I ran the Summit Roller Rocker arms before and they were fine. I put 120 hrs on them and the next owner did the same with no issues.
I have two sets of used crane energizer roller rockers I'd sell for $100. They ran fine but made a little more valve train noise then I wanted, so I bought comp cams pro magnum rockers. The energizers are just laying around now taking up space.
BT :cool: |
Rockers
You're asking for trouble using stock rocker arms with anything other than stock lift cam. I've seen pushrods eat a hole through a stock rocker.
The stock rockers will hit the rocker studs at anything more than .550 lift. There are long slot rockers that are stamped steel for higher lifts. However higher lifts usually mean higher spring pressures and /or roller cams. I wouldn't feel comfortable using stamped steel rocker arms for that.
Originally Posted by PatriYacht
(Post 2090662)
| All times are GMT -5. The time now is 01:46 PM. |
