Alpine4/3/2 amp help >
Old 04-11-2007 | 04:05 PM
Default Alpine4/3/2 amp help
I have a Alpine 4/3/2 3553 amp and need to wire 6 speakers and 2 tweeters. Where do the wires go?Thanks.
boatguy94 is offline
Old 04-11-2007 | 04:24 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Can it be done this way?
6 spkrs.
3 to 1 left channel, wired 2 in series and the 3rd in parallel. That should cancel the ohm doubling or 1/2ing.
Remaining 3 wired to other right channel in same fashion.
Tweeters to remaining 2 channels (1 tweeter per channel)
US1 Fountain is offline
Old 04-11-2007 | 05:27 PM
Not sure what you mean? There are 4 terminals on top and 4 terminals below it. The 2 on the left say - and +, 2 on the right say - and +, with the 2 outside ones saying bridged. Same for the 4 below. Electrically impaired as you can tell.
Old 04-11-2007 | 06:25 PM
Basically, you have two right channels, and two left channels. Channel=speaker. If you have a pair of speakers that have separate tweeters you need a crossover. If you wire the tweeters direct to the amp, you will blow them.
You need the + and - to go to each speaker. Forget about the "bridged" labeling, you will not be bridging the amp.
Lets say you have four cockpit speakers and two cabin speakers. I would run all four speakers off top left and right channels on the amp. Then run the cabin speakers off bottom left and right. This way you can fade the cockpit speakers out if you were chillin in the cabin at night. This is assuming the speakers are 4 ohm, and the amp is 2 ohm stable.
MILD THUNDER is offline
Old 04-12-2007 | 12:34 PM
IM4A2Z's Avatar
Exactly
IM4A2Z is offline
Old 04-12-2007 | 02:33 PM
Thanks for your help, will try it. I have crossovers for the tweeters.
bhyatt
TN Powerboat Club
18
10-14-2008 10:33 PM
SUPER AIR
08-24-2006 06:47 AM
Strip Poker 388
4
02-13-2004 07:34 PM
Toffen
0
02-02-2003 01:17 PM
Secret F233
08-08-2002 05:37 PM
