-   -   Mold on seats, boat out of storage. (https://www.offshoreonly.com/forums/general-q/155922-mold-seats-boat-out-storage.html)
offthefront 04-15-2007 06:04 AM
I would think the stains will eventually fade ...Like it was said some sunlight will help alot ... But if they do have to be replaced .... Mcleod Makes the Interior on the upgraded Baja's ... you can get replacements direct from them ....But I expect they will clean up ....m
G Man 04-15-2007 07:06 AM
Thanks, did what the storage facility said. Charcoal, lysol. Live in eastera Pa. Had the boat in an underground mine. Temp constant 50-55 degrees.
offthefront 04-15-2007 08:01 AM
I was thinkin ... did you clean the boat up right before you put it in storage ? Maybe it was still wet .. or water in the Bilge ? If your cover does not breath well the moisure has no place to go ....m
G Man 04-15-2007 08:07 AM
No, it was dry. Maybe reaction of Franzy and Lysol???
Can you provide more detail on Mcleod? I tried googling it and didn't come up with anything.
offthefront 04-15-2007 08:28 AM
http://www.mcleoddesign.com/Sub/Products.html
Downtown42 04-15-2007 08:46 AM
Had the boat in an underground mine. .
I'd find another place above ground next year. :et:
The sun will eventually bake the chit off with some bleach as stated above.
G Man 04-15-2007 09:19 AM
YEah, never again.
thanks !
smokinbob 04-15-2007 10:01 AM
DOWNTOWN42 is right, be patient, bleach solution then as much sunlight as possible, it WILL disappear.
DORaymond 04-15-2007 05:56 PM
Try some WD-40, I have found it takes everthing off of vinyl.
Liquid Liability 04-16-2007 07:58 AM
G-Man,
A friend of mine turned me on to a product called JOMAX which is designed specifically to remove stains and permanently kill the microbe's that cause mold and mildew to grow and stain. I had to order it off the internet, but it works great. Best of luck.
