OK guys, the motors are out.......
the motors are out (for a repower and a bilge re do), the drives are off, the boat is 18 yrs old........should I take the gimble housings off and reseal?? how hard is that to do??......anything else you would do while its all apart?? twin 350/alpha 1s
thanks doug
thanks doug
if your that far along..go for it..its not that hard, givin the age I wiould pull everything off the transom and reseal..an ounce of prevention prevents a ton of girnding, itching ,scatching and money in the future. I redid a transom once..notice I said once, wasnt what I would call fun.
The tranon to transom assembly doesn't leak too often.
I would check for any play in the upper/lower swivel pins. It's probably worth the effort to replace the upper pin seals and bearing since these are the most problematic.
302Sport
09-19-2008 01:19 PM
32 thunder
07-09-2005 10:09 AM
razor1115
4
03-25-2004 11:13 PM
