Valve Covers >
Valve Covers
Valve Covers
Old 04-18-2007 | 12:36 AM
Thumbs up
I have ran harland sharp rockers for years on both gen. v & vI with no problems. I have ran EMI alum. covers on the last motors, But I did run tall moroso on another, But with EMI headers.
speedreeder is offline
Old 04-18-2007 | 06:25 AM
Pat McPherson's Avatar
Originally Posted by Griff
99.9% sure these are the studs you need. http://store.summitracing.com/partde...5&autoview=sku
I did this on a Gen V 454 Mag.
Those are the studs I bought.
Griff, did you install 1.7 or 1.8 ratio rockers or your 454Mag?
Did you notice any extra power?
Hey Jayhawk,
You go first, it's still too cold in these parts to work on the boat.
Patrick
Pat McPherson is offline
Old 04-18-2007 | 11:47 AM
jayhawk261's Avatar
I've gotta do the steering first. I'm probably going to order the rockers this week. It looks like just getting to them will require exhaust removal. I don't know that I'm feeling that sporty this early! I guess we'll see
jayhawk261 is offline
Old 04-18-2007 | 12:48 PM
Hey Jayhawk,
I used the Summit brand roller rockers in a 1.7 ratio. I upgraded the cam and needed them for clearance.
BTW, the Crane Gold's no longer need to have the corners ground off. They changed the desogn a little.
Griff is offline
Old 04-18-2007 | 03:16 PM
Jayhawk,
I have a set of Harland Sharp rockers 8 1.7 and 8 1.8 ratios I used for less than 1 hour. I added them while the boat was in the water trying to get more lift on the intake side. I got nervous and did not want to risk coil bind because I was at the limit for the springs. This year I just changed cams and springs to get the extra lift. And bought a complete set of 1.7.
So if you are interested before I put them on Ebay PM me.
1BIGJIM is offline
Old 04-18-2007 | 03:22 PM
jayhawk261's Avatar
Originally Posted by 1BIGJIM
Jayhawk,
PM sent
Old 04-19-2007 | 03:44 PM
Strip Poker 388's Avatar
Rob
this is a pick of the cast valve covers from Steff's/B&B Perf..like a lot of the rest mafg's it has the angle for clearence for the headers.It has about 1/4 inch clearence,so its real close.
I dont think the Moroso sheetmetal ones will work
Strip Poker 388 is offline
grand-illusion
Wanted
7
06-03-2008 10:57 AM
BLOWN85
2
03-02-2008 08:46 AM
Kidnova
5
11-08-2006 08:36 AM
Andy
7
06-17-2005 06:19 PM
thegreygoose
4
12-20-2004 11:46 AM
