3/8 stainless line with NPT ends?? >
Old 04-24-2007 | 09:29 PM
Full Force's Avatar
Default 3/8 stainless line with NPT ends??
I am looking for a flexible 3/8 stainless steel line with 3/8 NPT ends already on it, hopefully a swivel type, I am adding an oil cooler to my small block, I have the cooler and the block for filter, just looking for lines now, anyone know who may have something like that?
Full Force is offline
Old 04-24-2007 | 09:34 PM
I would just go to an aeroquip distributor and have them made up.
Griff is offline
Old 04-25-2007 | 10:31 PM
Full Force's Avatar
I might, I actually found something on ebay that may work
http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWA:IT
Old 04-26-2007 | 01:48 AM
articfriends's Avatar
Are you using this for your actual oil line? It seems pretty small to me,Smitty
articfriends is offline
Old 04-26-2007 | 04:23 AM
Full Force's Avatar
I may go 1/2 inch but the cooler adaptor has 3/8 outlets so i figured the 3/8 would be OK, should I do 1/2"??
Old 04-26-2007 | 05:43 AM
sounds like you might have a power steering cooler
jdub is offline
Old 04-26-2007 | 06:05 AM
No doubt, You need a cooler with 1/2" NPT bungs on it. If this is for engine oil, you will also want to plumb in -10 Aeroquip style fitting and hose. You can run a "push lock" style hose which is a bit less expensive and works well. I have most of what you need in stock. You know how to find me...
mrhorsepower1 is offline
Old 04-26-2007 | 06:11 AM
nocigarette's Avatar
How big is the cooler, diameter and length........When running oil lines it is always better to run at least a # 10 hose. the price difference between a push lock and a regular end is a little more exspensive but worth piece of mind..........Plus if you upgrade engine performance you already have the oil system up to par......The push locks scare me.....If ya use them i would hose clamp them......
nocigarette is offline
Old 04-26-2007 | 06:12 AM
jdub fire some pics of that 27 excaliber, love those boats
Old 04-26-2007 | 06:14 AM
what's up man. I will have some soon, putting the new mill in next weekend
jdub is offline
