454 Advice Needed
Ok need advice/opinions will this work.
Do you think I can get 500-525 hp at the prop out of the following build ? What would you recommend.? -Start with GM short block 454HO #12498778 -Heads Edelbrock Perfromer RPM Aluminum#6145- Intake 290 cc/Exhaust 110cc runners and chamber 110cc -Cam duration at .050" tappet lift (intake/exhaust) is 224/234 ; and using 1.7:1 rocker ratio (intake/exhaust) is 527/544.Valve lash is zero/zero and lobe centerline is 110 degrees. -Intake would be Dart single plane #41214000 or Edelbrock Victor 454-O with Holley 830cfm Any help appreciated. |
Originally Posted by Pantera24
(Post 2108103)
Do you think I can get 500-525 hp at the prop out of the following build ? What would you recommend.? -Start with GM short block 454HO #12498778 -Heads Edelbrock Perfromer RPM Aluminum#6145- Intake 290 cc/Exhaust 110cc runners and chamber 110cc -Cam duration at .050" tappet lift (intake/exhaust) is 224/234 ; and using 1.7:1 rocker ratio (intake/exhaust) is 527/544.Valve lash is zero/zero and lobe centerline is 110 degrees. -Intake would be Dart single plane #41214000 or Edelbrock Victor 454-O with Holley 830cfm Any help appreciated. I am running a mkIV block 7.4l with gm perf aluminum heads 110cc with 1.7 rockers zz502/502 cam wich is the same as what you have,zz502/502 intake. The only thing i have diff is i am running 10.7:1 compression with the srp 10:1 forged pistons and a BG 825 carb. If i use the 20hp per mph to figure my hp gains i picked up 200hp from the stock 330hp. I gained 10mph and still have some rpm's to find. So if i go from that i am pushing 530hp. I have not dynoed the engine so this is just a wag. If that makes sense:D |
You're basically building a 454cube version of a ZZ502 with a single plan intake.
I think you will be close to 500HP at the crank with headers. Probably more like 450HP at the prop. |
2 Attachment(s)
I believe the Edelbrock heads are the same as the GM perf heads.
I do remember reading a thread about a guy that started with a ZZ502. The engine dyno'd around 480 stock.
He had the heads ported, changed the cam to a 500EFI, and changed to a single plan intake. I believe the engine made around 550HP with the mods. You may consider starting with a 502 vs. the 454. |
It sounds like a 460-475 HP engine at the crank.
Cam duration at .050" tappet lift (intake/exhaust) is 224/234 ; and using 1.7:1 rocker ratio(intake/exhaust) is 527/544.Valve
IS THIS A ROLLER CAM? |
| All times are GMT -5. The time now is 01:06 PM. |
