-   -   SBC Water pump? (https://www.offshoreonly.com/forums/general-q/157560-sbc-water-pump.html)
24degrees 05-06-2007 03:05 PM
SBC Water pump?
The water pump went out on my 320 EFI......it looks like a standard small block Mercruiser part.
Is there a better pump to buy?.......or should I just go get one from NAPA or something?
I want the best quality.
Thanks.
jmherbert 05-06-2007 03:08 PM
If you are closed cooling, you can put a high quality automotive one on it. If you have open cooling, use the mercruiser. The automotive ones are steel internals and will rust without the antifreeze/coolant to protect them. The marine ones are brass.
pullmytrigger 05-07-2007 11:09 AM
ditto.......
