Overheat - How hot is too hot? >
Old 05-20-2007 | 09:03 AM
  #31
On the compression test, I was getting good numbers, 180lbs unit I got to the cylinders with water in them, and the water was throwing off my compression numbers, so I stopped there.
windsurfnut is offline
Old 05-21-2007 | 10:47 AM
  #32
Wobble's Avatar
SORE MEMBER
It is most likely going to be the head gasket, you may be able to check the intake gasket on disassembly, but it is not likely the cause. With the heads off, have them crack tested, complete valve job may be a good idea depending on the hours, relatively cheap once the heads are off anyway, the head will need to be surfaced normally.
Wobble is offline
Old 05-21-2007 | 04:15 PM
  #33
thanks wobble. What's a marina usually charge for that kind of work?
Old 05-21-2007 | 04:44 PM
  #34
I had the exact same problem 2 weeks ago as you have now.Starboard exhaust riser leaking into the cylinders and port head gasket blew which allowed water into the cylinders as well.
Had the entire top end removed and found valves not seating properly.Good valve job,good intake and head gaskets and new Imco exhaust installed and all is good now.
If you do have water in the oil you need to do a couple oil changes asap.That water is tough on bearings.
Prostreeter is offline
Old 05-23-2007 | 08:14 PM
  #35
mtgbiker's Avatar
worked on a 5.7 efi this week that ran hot 2 cracked heads one broken exhaust valve two blown head gaskets!! ran hot enough to burn exhaust hoses.
mtgbiker is offline
Old 05-23-2007 | 08:17 PM
  #36
Thanks,
Was it exhibiting similar problems as mine?
estimated costs to fix something like that?
Old 05-24-2007 | 10:34 AM
  #37
Wobble's Avatar
SORE MEMBER
Thanks,
Here is the deal on the cost. If you know of a mechanic that can be trusted, then you have to do the work he wants done for the price he wants, in return if it's not right he takes care of it.
You could be looking at 1500-3000 per engine + any major parts that need replacement.
Now if you can remove and replace the heads yourself, the rest of the work without a new head could be less than $500 parts and machine work.
If you are not comfortable with this job consider pulling the motor yourself, which is fairly easy with a buddies help. This will save on the mechanics time, however he may not warranty his work if he doesn't do the whole job.
Good luck
Wobble is offline
Old 05-24-2007 | 11:34 AM
  #38
Do you have to change the oil after overheating?
senzaspectre is offline
Old 05-24-2007 | 03:58 PM
  #39
Big Block Billy's Avatar
Post
Why not change the oil ? You might be changing cranks rods and bearings. At least check the oil for signs of bearing debris and metal dust.
Water boils at 212 and expands into steam. This is not good and can lead to head gasket failure as well as actually burn a path between 2 cylinders as well as the head if severely overheated. For some reason usually the heat riser passage , this usually happens in the center cylinders. This steam also pushes hard and because of higher cylinder pressures it temporarily can stretch head bolts and may not seem to be the culprit and head and gasket may seem fine sometimes. Small cracks in the upper head bolt holes in the block indicate a severely overheated motor , and motor may have other issues as well.
When motor gets mad hot it actually seeks cool water and wants to suck it up the exhaust with vacuum. This could 'Splain rust in exhaust. Post some pics and some experts will tell you whats going on. BBB
Big Block Billy is offline
klmken
2
07-03-2006 12:14 AM
HARRISONMIRAGE
12
04-18-2004 12:49 PM
Miss Bud
10-21-2002 09:22 AM
