Compression on 5.7 EFI >
Old 05-15-2007 | 10:20 AM
Default Compression on 5.7 EFI
What should the cylinder compression be on a 5.7L 350 EFI motor (1999)
windsurfnut is offline
Old 05-15-2007 | 10:53 AM
dumb question, but I've only done compression checks on 2 stroke motors with kill swtiches, but what is the best way to disconnect the coil to avoid sparking/coil burn out when doing this test?
Please be specific, I'm in learn mode here!
Old 05-15-2007 | 11:06 AM
jayhawk261's Avatar
As long as your kill switch is in the off position, you should be fine. I just ran a compression check a couple of weeks ago with no problem.
jayhawk261 is offline
Old 05-16-2007 | 09:25 AM
I don't have a kill switch.
Anyone on the proper compression numbers on this motor?
Old 05-16-2007 | 09:37 AM
Just take the coil wire off. The PSI should be around 140-150.
As rule of thumb all cylinders should be with 10% of each other.
You don't want to see 150 in one and 90 in another
1BIGJIM is offline
Old 05-16-2007 | 09:42 AM
By coil wire, I want to clarify. Is this the wire that goes from the coil to the distributer?
Old 05-16-2007 | 11:57 AM
Dave_N's Avatar
On an engine equipped with the Delco EST distributor I usually remove the two harness connectors at the distributor, for T-bolt systems, I just take the wires (purple) wires off the positive side of the coil. Just removing the coil wire is not a good idea.
For a good compression test you should have a fully charged battery and the throttle plate wide open. It's ok to do it on a cold engine. You probably should see about 170-180PSI on an EFI small block. Big block would be more in the 145-165PSI range.
Dave
Dave_N is offline
Elite Marine
20
09-12-2008 05:28 PM
Formula311-SR1
2
10-08-2007 09:04 AM
FormulaM2Formula
04-04-2006 04:30 AM
BOATING ON A BUDGET
4
02-14-2005 09:31 PM
blown formula
31
06-10-2003 06:59 PM
