Hook in Powerquest 256?? >
Old 05-25-2007 | 03:13 PM
Default Hook in Powerquest 256??
I built some new 20in trim tabs for my powerquest this winter. Worked out great using the stock actuators. While I was mounting them (flater and more inboard than the stock tabs), I noticed a pretty serious Hook molded into the transom. between the outer and middle chines. There doesn't appear to be any hook between the keel and the first chines.
This boat really likes a lot of stern lift, probably because of this hook. I'm guessing Powerquest designed this in for a better pleasure boat ride when no tabs are used. However now that I've got some serious tabs in the back (enough to plant the bow at any speed), do I really need this Hook? I've got to figure it's really slowing the boat down for no good reason (now that I have the good tabs???
Any thoughts on this?
How hard would it be for a good hull guy to take this out?
I just spent the winter on this nice power upgrade and it seems like I may be running into limitations with the hull (have to really trim the drive WAY up to get it to run)
bcarpman is offline
Old 05-26-2007 | 10:05 AM
I'm now told this is called a "wedge". I'm still looking for some thoughts on this. The new motor dynod at 460hp and it's not pulling a 25p prop. I'm experimenting with props that a buddy has, so maybe it's my first prop choice. I'll try a 23p when it stops raining, but that definately won't give me the top end this motor should give.
Below are some drawings. I'm wondering if it's laid up like the second pic or like the third? If it's like the second, then it couldn't just be sanded and gell coated, and would end up being more work than I want to put into this boat.
bcarpman is offline
Old 05-27-2007 | 05:37 AM
masi242's Avatar
I have a 87 formula 242LS and it also has a small hook built in from the factory. Yes it will take a few mph from you. Just something you have to live with in an older boat.
good luck
masi242 is offline
Old 05-27-2007 | 09:39 AM
Post this for "offshore Ginger" to read, in the fiberglass and paint section this is his speciality.
johnny b good is offline
Pure Energy
0
10-15-2005 05:13 PM
SSComp
2
05-06-2004 01:30 AM
fastlane40
0
04-23-2004 02:54 PM
SSComp
0
09-11-2003 11:21 AM
johnnyboatman
5
11-16-2002 10:20 AM
