What would cause this?
My neighbour has a small Donzi, 25 or 28.
single 454 injected
When he brings it up to about 1200 rpm the motor just quits.
Makes an air suction sound and just quits.
If you start bringing up the rpm and right at the 1200 rpm mark spray some starter/either then it goes past the 1200 and runs fine.
Does this in gear and in nutral.
single 454 injected
[QUOTE=Midnight__Express;2142086] spray some starter/either /QUOTE]
Cant help you with what sounds like a fuel injection problem but ..... the only place for the starting spray is in the trash can .... that stuff is the best way to kill an engine. If you insist on using something, use Gumout or 2+2 carb cleaner. It will accomplish the same thing without hurting anything.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Bill Koustenis
Waldorf Md
