Bravo 1 to HP transom >
Old 05-31-2007 | 09:55 PM
Default Bravo 1 to HP transom
Can a bravo 1 outdrive be installed with a HP transom/gimbal and not just the standard bravo transom? Reason why i ask is if the bravo 1 has been upgraded with internals then can you directly bolt it to a HP assembly. Also, can a bravo 1 outdrive be hooked up to a IMCO HP transom assembly that has their integrated external steering instead of buying aftermarket steering such as latham that you have to install onto the transom of the boat? Thanks
daveintexas is offline
Old 06-02-2007 | 01:46 AM
offthefront's Avatar
you can use a B1 drive on a HP assembly ...stock or modified ....call Ron at Imco about the Imco setup ...m
offthefront is offline
wrasse
05-28-2007 09:05 AM
98itrwhite
4
10-05-2006 04:07 PM
Scarab28
5
07-09-2005 03:53 PM
magnum
3
08-01-2004 10:27 AM
