496 risers
Old 06-01-2007 | 07:29 PM
ENFORCER24's Avatar
496 risers
quick simple question
will 496 mag ho risers bolt to stock mercruiser manifolds ?
i know that water piping is different , the stock 454 manifolds use a wet joint between manifold and riser , and the 496 uses a dry joint , but i could plumb past that
is the bolt square the same?
ENFORCER24 is offline
Old 06-01-2007 | 09:37 PM
Wink
No, the 496 risers are a different bolt pattern and dimensions than older Merc manifolds including the dry versus wet joint.
I believe Imco and Gil both made some special risers for these older manifolds a few years back but I don't know if they are still available and how much of a real improvement they would make. I think you should really eliminate the wet joint manifolds and invest in some newer style manifolds which will also really improve horsepower. Seems like most cheap fixes are just that , not always worth the effort or perceived savings.
Ray @ Raylar
Raylar is offline
Old 06-02-2007 | 01:14 AM
Fenderjack's Avatar
Pirate of the Chesapeake
No the 496 is it own seprate breed..
John
Fenderjack is offline
Old 06-02-2007 | 08:32 AM
I have a set of 496 manifolds if you are interested. Cheap! They need cleaned up and painted but were working. Came from a 98 496.
never.enuff.stuff is offline
handfulz28
10
02-13-2008 03:27 PM
sonic28
4
11-30-2007 11:44 AM
35 White Lightning
3
05-14-2007 01:09 PM
Whiteknuckle
9
01-09-2003 11:27 AM
