Injector testing procedutre >
Old 06-03-2007 | 03:02 PM
Default Injector testing procedutre
What's the best way to test a fuel injector on a Merc. 502 MPI ecm 3? I don't know if the injector itself is bad or if it isn't getting a voltage signal. Can I hook a voltage meter or an LED to the wires of the injector, crank the engine and look for a voltage signal? (There are no error codes.)
ctuck0659 is offline
Old 06-03-2007 | 04:21 PM
H2Xmark's Avatar
the injectors should ohm about 10 to 13 ohms, you can use a test light across the injector wires, just dont let it run long like that, look for a good pulse of light from the test light
H2Xmark is offline
Old 06-03-2007 | 06:32 PM
t500hps's Avatar
21 and 42 footers
Trust me...injectors can destroy a motor. I'm re-building a motor now (with some buddies) that detonated and "came apart" after 2 hours due to bad injectors.
I found out the injectors were my problem by sending them to Marren Fuel Injection (injector.com). He was able to test them and tell me which injectors were the problem.
t500hps is offline
kennyo
5
12-29-2006 03:00 PM
Donzi502
2
11-21-2006 10:11 AM
RonS
1
07-22-2004 07:01 AM
thegreygoose
1
03-05-2004 08:08 PM
Luv-N-It
3
04-12-2003 12:22 PM
