500hp  Gurus !!! >
500hp Gurus !!!
500hp Gurus !!!
Old 06-06-2007 | 12:22 PM
Pat McPherson's Avatar
Originally Posted by speediseverything
I am told it is a 2002 but it has a carb, This motor is going in an Advantage Citation 22ft. It has gil exhaust right now.
Port the heads, change to a little more cam, and 550HP will be no problem.
Patrick
Pat McPherson is offline
Old 06-06-2007 | 12:28 PM
Is there a difference when porting the heads for a car or a boat application. What rpm should i spin this motor at.
speediseverything is offline
Old 06-06-2007 | 12:29 PM
Originally Posted by razor1115
Carder,
What speeds are you seeing? What is your set-up?
Bravo 1's on Stelling boxes, 1.5 gears.
29p Quad IV's hit the rev limiter of 5600 at 87 mph... with about 2 inches of unused throttle.
I have a problem with the stbd. drive, currently, but when that is resolved Julie at Throttles-Up has sent me a set of CNC 29p 5 blades to try.
Carder is offline
Old 06-06-2007 | 12:33 PM
Tyler got around 100 hp from simply doing the new Dart heads and a port job. The cam and MSD were icing on the cake... The dyno showed the MSD alone added 12 more hp.
Carder is offline
Old 06-06-2007 | 12:38 PM
razor1115's Avatar
Are the boxes -2 raising the x-dim?
razor1115 is offline
Old 06-06-2007 | 12:40 PM
The boxes both set back the props as well as raise the X
Carder is offline
Old 06-06-2007 | 12:56 PM
Why is the 500hp 500horse and the 502mag is only 415. Whats the difference
Old 06-06-2007 | 12:57 PM
razor1115's Avatar
Thanks Carder...I suspected as much with those speeds.
Old 06-06-2007 | 01:35 PM
From what I've read and been told the exhaust ports need work on the Chevy heads.
5600rpm should get you 550+HP.
Patrick
Old 06-06-2007 | 01:37 PM
Intake, valve size, cam, exhaust...
Patrick
