Compression ratio with 049 heads >
Old 06-11-2007 | 05:58 PM
Linster's Avatar
Off the Radar
Originally Posted by jackhammer
That is until I used this calculator on the KB site. I understand how cam timing effects CR (intake valve not closed at exactly BDC), what I don't understand is how a rod length can effect stroke!? In my mind a 4.25" stroke is a 4.25" stroke... even if you put a 10 foot rod on it the stroke will still be exactly 4.25". I may have to call KB to get this one explained.
Rod length changes the angle of the rod vs crank. It really changes piston speed from the 11-1 oclock postion. A shorter rod tends to stay at TDC a little longer and is lazy approching or leaving TDC. A longer rod keeps the piston moving faster in that area. Keep in mind that is the spark area on the compression stroke. On the intake stroke. a longer rod starts sucking faster as the piston moves quicker, which is needed with a longer stoke. Hope that helps.
Linster is offline
Old 06-12-2007 | 07:20 AM
I think I get it... but how does the faster piston have a dynamic effect of shortening the stroke? the accelerated piston physically cannot suck as much air?
jackhammer is offline
Old 06-12-2007 | 07:36 AM
mtgbiker, I pretty much did exactly what you suggested. I backed off the crane 731 a notch. If I achieve a reliable 475hp at 5000rpm I'll be happy. I plan to spend most of my time in the upper mid-range where I hope to stay above 600 torque.
I really struggled with the intake, but in the end I chose the Performer RPM dual plane (port matched is all). If someday I want more top end out of the engines I can get more flow with intake and heads. Probably not on this boat though. It's an old heavy scarab.
Old 06-12-2007 | 07:44 AM
PatriYacht's Avatar
Maybe the longer rod affects dynamic comp. ratio,but it doesn't affect static compression. That is simply a fraction. Volume of cyl. and head, piston down over volume of cyl. and head, piston up. Merc. always used 8.8 to 1 with 89 octane, 9.4 with 91 octane seems ok but Merc. was always conservative with fuel/ air mix and timing. Don't use a thick head gasket. Keep the piston to head clearence at .040 for best performance and knock control. Using thicker head gaskets to cut compression will actually make knocking worse.
PatriYacht is offline
Old 06-12-2007 | 08:24 AM
hoozeyurdaddy's Avatar
here is a web site that has some cool calculations.
http://www.golenengineservice.com/html/calculators.html
it will figure all kinds of things if you have the basic info.
hoozeyurdaddy is offline
Quaid24
16
03-03-2008 11:38 AM
ENFORCER24
34
01-26-2008 12:15 PM
seahawk
2
05-24-2004 12:21 PM
daveo1
7
02-04-2004 09:17 PM
wetterthebetter
2
01-03-2004 05:06 PM
