CARB help
Old 06-08-2007 | 09:29 PM
Default CARB help
I have a holley 850 and need to run a vacuum line to the distributor. Which do I use? It has to be no vacuum at idle and ramp up with rpm. Thanks
horsepower452 is offline
Old 06-08-2007 | 09:33 PM
monstaaa's Avatar
i believe its the port on the right front. but why do you need a vacum line?. arent you using a locked out distributor.
monstaaa is offline
Old 06-08-2007 | 09:42 PM
I was but my crane box died so I went with a MSD box. I still have the crane dist which has vac and rpm adjustments. I noticed a loss in top end power and realized I was running no advance so I went to set up the crane and got the RPM advance worked out but now it runs real rich and stutters. I also noticed my fuel pressure is at 10 psi and drops to 9 psi at wot. With everything locked out it seems to run fine but no top end power.
Thanks for help
Old 06-09-2007 | 06:54 AM
monstaaa's Avatar
as for the fuel pressure, it should be mor earound 7 psi.
what kind of sock ignition did you have. typicly most conversions use the stock mercruiser, and guys usually use a v-6 module, thunder bolt 4 or 5 h.p ones also work well. they give you a total advance of 34 when timing is set right. then add on the msd for better spark/ ignition.
i myself have done this, but as of late started usind the msd digital 6 plus, as it has numerous timing curves built in. as well as rev limits and inital timing settings.
monstaaa is offline
tssteph
Wanted
2
07-31-2008 08:14 AM
jtwpwrboat1
8
10-25-2005 07:13 PM
East Coast B
4
07-08-2005 03:57 PM
Dean Ferry
05-15-2002 02:00 PM
