Keith Eickert header question >
Old 06-10-2007 | 09:44 AM
ls1nova's Avatar
Default Keith Eickert header question
On the inside of each header there are 2 round bosses that appear to be welded in the middle. Does anyone know what they are for? Do they go all the way into the inner port? Reason I ask is I would like to drill and tap one for my wideband O2 if they go all the way through.
Here is a pick of what I'm talking about.
Attached Thumbnails Keith Eickert header question-ke-headers-001-large-.jpg   Keith Eickert header question-ke-headers-002-large-.jpg
ls1nova is offline
Old 06-11-2007 | 06:44 AM
Computer and shifter bracket mounts.
Allen
29scarab10 is offline
Old 06-11-2007 | 10:53 AM
ls1nova's Avatar
Thanks, Allen. but those are the smaller ones that are already drilled and tapped. I'm refering to the larger ones to the left and right.
Thanks,
Frank
ls1nova is offline
Old 06-11-2007 | 08:59 PM
Frank -
Might have something to do with the casting process ?? Drill into them and you might hit water, might hit exhaust. If you do drill into an exhaust port, it would just be one port. Don't 02's like to be at the collector, read all 4 cyls ??
Kidnova is offline
Old 06-11-2007 | 09:07 PM
Can you put the fitting in the tail pipe?
BenPerfected is offline
Old 06-11-2007 | 09:19 PM
bob
Charter Member #40
Put mine in the tailpipe by the flange. Work fine. The only area I think you will find a solid aluminum wall to the exhaust is down by a port on the first three inches or so. I don't think I would be drilling into the area you mention.
bob is offline
Old 06-12-2007 | 10:07 AM
ls1nova's Avatar
Thanks for the input guys. Right now I have it in an aluminum spacer I made that goes between the tail pipe and header. If you look close in the first picture you can see it. I was actually just curious if I could move it a little farther down, but it doesn't seem to be getting wet like I thought it would.
Frank
ls1nova is offline
LubeJobs42
04-26-2006 12:01 PM
BajaBennett
3
11-29-2005 12:30 PM
BLee
08-19-2003 10:43 PM
Kernan
06-25-2003 02:04 PM
