496 belt problem >
496 belt problem
496 belt problem
Old 06-11-2007 | 08:11 PM
Default 496 belt problem
Can anyone help me I have a 496 that the belt under rpm wants to slide then it schreads the belt. I have replaced the drive water pump still does it can anyone help. thanks chris
bozsage is offline
Old 06-12-2007 | 12:03 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Start simple. Double check you installed all the small bolts back into the pump properly to ensure a good alignment of the pump pulley. If it's out of alignment, it will slide off like a bicycle chain would. Besides alignment, and proper tightness, there's no reason it should slide off.
Reckless32 is offline
Old 06-12-2007 | 06:58 PM
monstaaa's Avatar
i have seen on the newer models , that the springloaded belt tensioner gets bound up due to corrosion and lack of lubrication. this causes a bind spot if you will . then when under load at rpm the belt starts to flutter and pop off or shred or both.
good luck.
monstaaa is offline
fountain27ho496
07-15-2008 09:35 AM
JohnnyG
2
07-06-2007 12:54 AM
Shooter
4
11-09-2006 08:55 PM
rssteiny
2
06-22-2005 08:59 AM
Frequency
9
06-16-2002 08:45 AM
