Oil change Question. >
Old 06-13-2007 | 08:51 AM
Default Oil change Question.
I'm basically changing my oil every 15 hrs. because it gets so black. I'm running a procharger on a 509 and it runs great. Maybe a little on the rich side but i'm okay with that. The oil really doesn't smell like gas.
I currently run M-1 20w50 syn. and M-1 filter. I guess I have two questions. What filter flows better and since I change it so often could I go to a cheaper Dino based oil?
I've search all the threads and never really came away with a definitive answer.
kennyo is offline
Old 06-13-2007 | 10:43 AM
ttt please.
kennyo is offline
Old 06-13-2007 | 10:53 AM
GLH's Avatar
GLH
This might help you...
http://www.offshoreonly.com/forums/s....php?t=107808&
GLH is offline
Old 06-13-2007 | 02:49 PM
there is current info as to oil filters on the last page of marine oil lube
good luck Jamie
Jamie Bowman is offline
Old 06-13-2007 | 03:14 PM
I saw that. So the wix#1794 is the two qt and it flows better. Does it also have the syn media? The oil filter comparison page won't load.
kennyo is offline
Old 06-14-2007 | 12:31 AM
articfriends's Avatar
My boat holds about 16-17 qts of oil and I change it every 10-15 hours too,I been using 12 qts of 20 w50 kendal gt and topping off with 20w50 m-1,bearings looked like new when I tore it down this year to freshen it. This is a hyd roller application like yours,if I had a flat tappet cam I would find something with alot of zddp but this mix is working great for me,Smitty
articfriends is offline
Old 06-14-2007 | 08:31 AM
Holy Sh*t! 17qts? I don't feel so bad now. So mixing the M-1 And regular oil is okay? I really just wondered if a good dino oil change every 15hrs would be as safe as syn oil. It would save me about 35-40 bucks a pop. On the other hand if it keeps the engine together I guess it's worth it.
kennyo is offline
Old 06-15-2007 | 01:31 AM
Kendall gt1 used to have all kinds of zddp and other great properties when it was still "green" looking and made to its original specs and was a favorite of many racers. It has since been watered down like most others (from what I read) and reformulated. I still use it but I like to add the m-1 vtwin 20/50 to help fortify it as far as the zddp and stuff,at least thats my reasoning,it has never caused a problem,I might be wasting money but I tend to stick with what works for me. You could also just add gm EOS to any decent oil too and probably be ok,Smitty
jaxx 30
Scarab
5
04-10-2008 09:49 PM
seafordguy
9
08-04-2007 03:01 PM
pol98xc6
11
04-13-2007 06:30 AM
bcoffield
07-02-2003 05:05 AM
