Hydraulic Steering getting tight? >
Old 06-17-2007 | 12:59 PM
tblrklakemo's Avatar
SeaRay Sundancer
Default Hydraulic Steering getting tight?
After driving my boat (01, 27 fountain, 496HO, factory dual ram hydraulic steering) to an anchor spot, and letting it sit in the water for extended periods (at least a couple hours) of time the steering really firms up when we get back to boating. What could be causing this? Dont see any water in the reservoir. Engine heat maybe?
tblrklakemo is offline
Old 06-17-2007 | 01:20 PM
mats's Avatar
Low power steering fluid level as the fluid cools down?
mats is offline
Old 06-17-2007 | 03:55 PM
SeaRay Sundancer
No, the fluid level really doesnt move. It works fine when I go to start the boat, lets say, first thing in the morning. But after a long sit in the sun after running it hard, the wheel is much harder to turn.
Old 06-17-2007 | 04:58 PM
monstaaa's Avatar
filter
monstaaa is offline
Old 06-17-2007 | 10:00 PM
SeaRay Sundancer
Originally Posted by monstaaa
filter
Ahhhh.....I wonder where it is located? Inline?
Old 06-18-2007 | 06:31 AM
Turbojack's Avatar
Mine looks like a canaster that is mounted to the transom. High pressure line coming off of pump goes to cooler, then to filter.
Turbojack is offline
Old 06-19-2007 | 10:55 AM
SeaRay Sundancer
Anybody else? Belt doesnt seem loose. Could it be a proportioning valve that gets funky when warm? Am I going to mess stuff up using it still?
Thanks,
Old 06-19-2007 | 12:14 PM
ITLLFLI's Avatar
Filter
ITLLFLI is offline
Old 06-19-2007 | 01:00 PM
tssteph's Avatar
Mine kind of does the same thing. It is hard to get the steering wheel to move, once it breaks loose the steering is fine until I stop moving the steering wheel. I will have to check the filter.
tssteph is offline
Old 06-19-2007 | 01:49 PM
SeaRay Sundancer
Just ordered a filter.....stupid guys at fountain dealer said they never changed one before. Why would you have a FILTER, if it didnt need to be changed? 29 bucks from latham marine. Fits hydaulic steering made by fountain until 02'
