anther problem >
anther problem
anther problem
Old 06-17-2007 | 07:33 PM
Default anther problem
1995 baja 272 454 mag efi had problems running wot when engine was warmrd up got home and checked the codes 1. read coolant temp low temp the second one was mat signal voltage high should i go ahead and just change them both they where changed last year or does anyone know why the map would would read voltage high
morgansrun is offline
Old 06-17-2007 | 09:12 PM
monstaaa's Avatar
first you wrote m.a.t then m.a.p . if its a mat , iy may have been set due to improper winterizing. same for the coolant temp. is there a stat and is it working.
monstaaa is offline
Spooln
12
08-15-2007 09:58 AM
Brandon
12
08-14-2007 08:10 PM
Baddogg
10
08-07-2004 09:14 AM
timucin
25
12-05-2003 12:00 AM
