Mercury thunderbolt IV ignition advance module question >
Old 06-21-2007 | 07:13 AM
boatn70's Avatar
not to hijack your thread SS240, but could someone clarify whats really going on with the v6 module and the advance, does it really come in at 650 rpm? Im running mine on a procharged 502 and was wondering if im loosing something there, i have set initial at 14*, I will have to check total now to see whats up.
SS240, I think I have a module that you can try, I would want it back though!! keeping it in case i pull off the charger.
email me if you havent found [email protected]
b70
boatn70 is offline
Old 06-21-2007 | 07:16 AM
boatn70's Avatar
Originally Posted by Switzer SS240
While I could just set the total at 30-32, It dosen't seem right to have that much advance at that low rpm. Isn't that putting a lot of stress on the bottom end? I understand that when inertia comes into play from the higher rpm it doesn't matter, but it doesn't seem right for an idling speed. That's more of a question, not a statement. I'm new to all this stuff and certianly don't claim to be very knowlegable.
Im curious about this also.............
thanks
b70
boatn70 is offline
Old 06-21-2007 | 12:02 PM
b70
If you've got initial timing set at 14* with a V6 module your total timing is only about 24* You should set total timing at 30* and let the base fall where it may.
BTW, a V6-14 module only gives about 10* advance on a V8 engine.
Griff is offline
Old 06-21-2007 | 12:04 PM
thanks
b70
More timing at idle will not harm anything unless its really high--like above 36-40*
Even then, its really just hard on the starter, not the engine.
Griff is offline
Old 06-21-2007 | 02:45 PM
Thanks for everyone's imput. It seems the V6-14 module is not appropriate for my application and I should be using a V8-20. Being that I was planning on buying the MSD ignition control with built in rev limiter anyway, it just seems to make sense to make it a completly new MSD system. (The V8-20 module is about $250) Also, it's great to better understand how things work.
Switzer SS240 is offline
Old 06-21-2007 | 02:47 PM
Pat,
what's your email address so I can contact you directly?
Old 06-21-2007 | 02:55 PM
Pat McPherson's Avatar
Pat,
[email protected]
You may also look at DUI for a new ignition setup. If I had a carb motor that is what I'd run...
Patrick
Pat McPherson is offline
Old 06-22-2007 | 12:01 AM
You should set total all the time at around 4000 rpm and not worry about initial, it will fall where it may, no big dealio. Sounds like a bad module though.
ghittner is offline
alecsammy
10
07-27-2009 12:30 AM
SmallPP
16
08-01-2007 12:42 PM
Switzer SS240
3
07-02-2007 04:24 PM
djtalon
10
09-28-2006 09:17 AM
26scarab
4
07-17-2003 07:11 PM
