oil cooler
Old 06-20-2007 | 03:25 PM
Default oil cooler
Whats the best flowing oil cooler out there, also have a cooler that's had a engine blow while in use is there any way to reuse?
duke is offline
Old 06-20-2007 | 07:50 PM
Wobble's Avatar
SORE MEMBER
don't reuse that cooler, you will find several people here that have trashed new motors by using their old contaminated cooler.
As far as your other question, how much HP are you running and where do you boat, both these questions will have a bearing on the answer
Wobble is offline
Old 06-21-2007 | 07:47 AM
Check this link out ..http://www.offshoreonly.com/forums/s...ght=oil+cooler
myscarab30 is offline
Old 06-21-2007 | 08:39 AM
Biggus's Avatar
[QUOTE=Wobble;2170797]don't reuse that cooler, you will find several people here that have trashed new motors by using their old contaminated cooler.
....me being one of them
Biggus is offline
Old 06-21-2007 | 09:38 AM
[QUOTE=....me being one of them[/QUOTE]
Me to . Thought I was smarter than that
1BIGJIM is offline
Old 06-26-2007 | 08:20 AM
900 hp, boat is mostly ran at a in central iowa.Was running a hardin marine 1000hp with thermostat engine builder said to much restriction
duke is offline
Old 06-26-2007 | 08:41 AM
there are several in the classified adds right now. where are you from ? I don't see many other boats around here with big power .
awesomecat26 is offline
Old 06-28-2007 | 03:09 PM
do must of boating at sailorville
duke is offline
Old 06-28-2007 | 04:07 PM
i know this will be a minority opinion, but i have cleaned and reused oil coolers with 100 % success.... many many of them. there is really no reason or configuration issue that i can imagine that made me ever think otherwise. you flush them, wash them, flush them again... solvents , hot soapy water, more solvents... them hi pressure wash in both directions... hi pressure air with cloth over the end ... etc etc... and thats w/ automotive racing coolers which are 100 times harder to clean than these marine heat exchanger type...in prep to writing this , i took the cooler off my old 454 and cut it in half to see what was inside...and its nothing more than a tube bundle... no nooks or crannies to capture or hide anything...
it might take maybe an hour to clean one properly. . for sure if you think you are just going to run some safety clean thru it for a few minutes you are kidding yourself... but if you clean it like you would clean a block or anything else with small passages you will be fine... also... think about it....
if the cooler was BEFORE the filter and therefore contaminated, when you put it back after cleaning, , on the off chance you issed a flake, the filter will catch it...
if the cooler was AFTER the filter, then what do you figure was in it in the first place ?
i think this whole bogeyman " the devil lives in my oil cooler" thing is just nonsense.
stevesxm is offline
t500hps
07-17-2012 09:23 AM
J. Hordubay
13
10-02-2008 01:55 PM
31scarab31
2
02-29-2008 04:14 PM
slik22
Wanted
6
01-08-2008 04:13 PM
patrick22309
5
06-20-2003 05:53 PM
