500 efi starter issue
after you run it drain the water from the bottom of the CMI's , let it sit for a few days and if it still acts up then its not water, but if it starts fine you might have a leaking header, I hope not they are big bucks. I rigged up an automotive radiator pressure tester to pressure test my exhaust,
Was yours leaking at the flange or somewhere else. I was trying to figure out it the headers are mandrel bent as one piece inside or if it has welded splices in it.
WHEN YOU TAKE THE HEADER OFF AND LOOK WERE IT BOLTS TO THE HEAD THATS WERE MINE LEAKED THATS WHY IT ONLY WENT IN ONE HOLE...
Well it's been two years now and still have not found the problem. It's not the headers leaking, I've replaced the battery cables, I replaced the starter. Now when I turn the key I get a single click, then nothing. Turn it again and and the same thing, sometimes it take three or four turns before it will turn over. Yesterday I shut the boat off two times and it did it both times. Friday I started the boat for the first time of the season and it did not do it at all.
