Need .040 stocked blower piston... Help. >
Old 06-29-2007 | 12:14 PM
Default Need .040 stocked blower piston... Help.
I need a blower piston in a 454 block with a 6.385 rod @ .040 over and JE or SRP has to do them custom. Does anybody here know of a manufacturer they like other than JE that makes a .040 oversize of the shelf?
ghittner is offline
Old 06-29-2007 | 01:14 PM
rmbuilder's Avatar
MarineKinetics
ghittner,
http://www.diamondracing.net/Diamond2007.pdf
Pg 17/18 depending on CR
Bob
rmbuilder is offline
Old 06-29-2007 | 03:31 PM
You also need the same weight piston the keep the rotating assembly balanced
BenPerfected is offline
Old 06-29-2007 | 03:40 PM
rmbuilder's Avatar
MarineKinetics
Sprague,
100% correct, I read pistons, not piston.
If you are replacing only 1 piston you will need a direct replacement not only for weight but material compatability (thermal expansion), ring sizing etc.
Bob
Old 07-06-2007 | 01:17 PM
Set of 8, thanks
ghittner is offline
Donzi38ZXXX
2
05-13-2007 11:46 AM
TRYME
44
12-18-2006 04:05 PM
Gary Anderson
19
07-16-2005 07:58 PM
homan
10
11-23-2003 07:55 PM
