hydraulic fluid ? >
hydraulic fluid ?
hydraulic fluid ?
Old 07-01-2007 | 03:37 PM
Default hydraulic fluid ?
I was checking my fluids and noticed my hydraulic trim resevoir tank was just under full and it dawned on me i don't know what type fluid it is
coolhand502 is offline
Old 07-01-2007 | 06:56 PM
Either the quicksilver power trim or SAE 10W-30 or 10W-40 (regular motor oil). Per the service manual. I have been running 10W-30 for a couple of years.
Rene
oldandtired is offline
Old 07-01-2007 | 08:55 PM
Rene
I failed to mention it looks red
Old 07-01-2007 | 09:35 PM
jayhawk261's Avatar
I just replaced a trim pump reservoir on Saturday. The marina's mechanics use Dexron III ATF, and that's what I used. Works fine for me.
jayhawk261 is offline
Old 07-01-2007 | 10:01 PM
thats what i figured just wanted some opions thanks
Old 07-02-2007 | 07:31 AM
i called merc direct and asked them when i got mine.... they told me 10-30 motor oil. i put the same mobile 1 in those that i do in the motor and they have remained clear and clean as opposed to the other which turned grey and ugly in short order
stevesxm is offline
Old 07-02-2007 | 01:02 PM
so it sounds like atf in the boats trim res. and 10w30 in the outdrive trim
Old 07-02-2007 | 01:20 PM
ziemer's Avatar
You can run ATF or 10W-30 in any or all. The pumps are the same. ATF will give you a little faster trim though.
ziemer is offline
Old 07-02-2007 | 08:14 PM
Cool
COOL ya'll rock, thanks for the help you guys. never had a boat with all these hydraulics onboard !!!! thanks again
Luke
Deltarat
Drives and Lower Units
3
09-08-2008 12:28 AM
Ken N
2
10-07-2007 05:26 PM
KN
6
04-21-2007 09:59 AM
Whiteknuckle
49
12-07-2005 07:16 PM
vonwolske
6
04-26-2005 07:36 PM
