Easy engine alignment question for you experts >
Old 07-08-2007 | 07:08 PM
Default Easy engine alignment question for you experts
Ok we put a new 350 in my wellcraft, I bought that tool to align the engine with the outdrive shaft, greased it up, inserted it and then when I pull out the tool, there is only about one inch of spline marks on the top of the tool and on the bottom there are spline marks the whole length of it. Does the motor need to come up or down? It seems like I have went up and down to the extreme already. Please help, I need to hit the water
woodsbrothers is offline
Old 07-08-2007 | 09:09 PM
Not that I am an expert, but I just went through a similar problem with my boat. I finally got the engine set to where the tool would slide in and out real easy, but the marks in the grease were like yours. After an hour of adjusting I got it back to where it was easiest and left it that way. The outdrive goes in and out like a dream! Any info would be nice!
DKerns is offline
Old 07-08-2007 | 09:36 PM
Where on the tool are the splines hitting (topside)? If the marks are only on the very end of the tool, then the engine needs to go up. The bottom of the tool tends to get spline marks all the way every time that I have done an alignment. I guess thats because of tolerances, the tools weight and the fact that it was always close. If the tool moves freely with two fingers, then it's good enough.
Rene
oldandtired is offline
bob_t
11
07-17-2006 09:34 AM
1BIGJIM
1
03-20-2006 08:07 PM
35 White Lightning
Fountain
1
04-19-2005 09:18 PM
26sonic
15
06-18-2004 01:05 PM
Chart
3
06-27-2003 07:08 PM
