This injection is nice,but I'd rather be BLOWN >
Old 07-13-2007 | 07:32 AM
Default This injection is nice,but I'd rather be BLOWN
Anyone know how much boost I can put to an MPI3 7.4 without having to do ANY other mods other than bolt on a supercharger (paxton or magnacharger for example)
rumblfish1966 is offline
Old 07-13-2007 | 08:10 AM
I believe you can run the Prochargers up to 5psi with proper installation. That would be your safest option.
kennyo is offline
Old 07-13-2007 | 08:40 AM
I ran fine with 5#s on my stock 7.4 mpi: however the block had some time on it and I experienced blow-by (or so I thought). Then I put lots of goodies in and did not up-grade the injectors and then had to re-build again. Now it runs great with an in-boat ecu tune (expensive but well worth it). Net, Net if your rings will hold up, you may have to replace intake and head gaskets and get by with nothing else. If you are like most others on this site you might want just a little more and the blowers help you find the weakest part.
baronbob is offline
Old 07-13-2007 | 10:24 AM
I also recommend head gaskets and studs if the engine has over 100 hrs or so. It's alot easier to do with out all the s/c stuff hanging on it.
kennyo is offline
Old 07-16-2007 | 02:06 PM
Default Thanks !!
thanks for the input gentleman, i was thinking 4 PSI VERY safely but the hours are unknown so i think i better take it apart this winter and check it out before i blow it (literally)
Old 07-16-2007 | 08:11 PM
jeff32's Avatar
Man... Just reading the title of this tread, I thought I was in the unsensored section!!!
jeff32 is offline
Old 07-16-2007 | 08:19 PM
one piece of advice I did not follow but wished I had is to start with a different block. 502 if I had to do it all over again. The 454's and mag's have forged internals, which I now have but more inportantly they have rectangular intake port heads and therefore a different and superior intake/plenum.
baronbob is offline
knotrated
1
05-02-2008 03:49 AM
baja27
11-13-2007 11:46 AM
Stormrider
08-02-2006 04:35 PM
fulloblarney
8
01-27-2005 07:41 PM
bajah2x105
22
07-16-2002 04:30 PM
